The rooftop area is an important part of the house, even though it is not used daily. It plays a major role in protecting the building from weather conditions such as rain, sun, and wind. When accessed, the rooftop provides a clear view of the surroundings and helps in inspecting the condition of the roof covering and drainage outlets.
The surface of the rooftop is finished with materials that can withstand heat and moisture. Drainage points are provided to allow rainwater to flow away easily, preventing water accumulation. Regular inspection of the rooftop helps identify cracks, blocked drains, or damaged waterproofing that may cause leakage.
In some cases, the rooftop is used for drying clothes or placing water tanks and antennas. Proper arrangement ensures safety and prevents overloading. Guard rails or parapet walls provide protection and reduce the risk of falling.
In conclusion, the rooftop area supports both protection and inspection of the house. Proper maintenance helps prevent leakage and ensures long term durability of the building.
