When it comes to building or renovating a wooden house, many homeowners assume that wood siding is the only option. However, an increasing number of builders and homeowners are turning to non-wood siding materials, such as cement, to provide a durable and low-maintenance exterior finish.
Why Choose Non-Wood Siding?
So, why would you choose non-wood siding for a wooden house? Here are a few compelling reasons:
- Durability: Non-wood siding materials, such as cement, are highly resistant to rot, decay, and insect damage, which can be major concerns for wooden houses.
- Low Maintenance: Non-wood siding requires very little maintenance, as it doesn’t need to be painted or stained, and it’s not prone to warping or cracking.
- Fire Resistance: Cement siding, in particular, is highly fire-resistant, which can be a major advantage in areas prone to wildfires.
- Weather Resistance: Non-wood siding materials can withstand extreme weather conditions, including heavy rain, hail, and high winds.
Benefits of Cement Siding
Cement siding is a popular choice for wooden houses, and for good reason. Here are some of the benefits:
- Long-Lasting: Cement siding can last for 30 years or more, making it a cost-effective option in the long run.
- Pest-Resistant: Cement siding is resistant to pests, such as termites and carpenter ants, which can cause significant damage to wooden houses.
- Mold- and Mildew-Resistant: Cement siding is also resistant to mold and mildew, which can be a major concern in areas with high humidity.
- Design Flexibility: Cement siding comes in a range of styles and colors, making it easy to find a design that complements your wooden house.
Other Non-Wood Siding Options
While cement siding is a popular choice, there are other non-wood siding options available, including:
- Vinyl Siding: Vinyl siding is a low-maintenance option that’s resistant to warping, cracking, and fading.
- Brick Siding: Brick siding is a durable option that’s resistant to weathering, pests, and fire.
- Stucco Siding: Stucco siding is a popular choice for Mediterranean-style homes, offering a durable and low-maintenance exterior finish.
While wood siding can be a beautiful and traditional choice for wooden houses, non-wood siding materials offer a range of benefits, including durability, low maintenance, and fire resistance. Whether you choose cement siding or another non-wood option, you can enjoy a long-lasting and worry-free exterior finish that complements your wooden house.
