Tile floors and walls can add elegance to a renovation, but poor installation often results in cracks, lippage (uneven edges), or loose tiles. These issues usually occur when the subfloor isn’t level, adhesive is applied unevenly, or grout is rushed.
The Fix:
Cracked tiles must be carefully removed and replaced with new ones. For uneven tiles, the grout may need to be removed, and affected tiles re-laid with proper leveling spacers. If the subfloor is unstable, reinforcing or applying a self-leveling compound before reinstalling is essential.
Prevention:
The best way to avoid tile fails is surface preparation. The subfloor should be completely flat, dry, and clean. Using the correct thin-set mortar and spacers ensures even placement. Allowing grout and adhesive to cure fully before heavy use prevents premature cracking.
In conclusion, while tile troubles can be frustrating, they are fixable. With the right preparation, homeowners can enjoy durable, beautiful surfaces that last for decades.
