Things you don't knwo about solarskin coating
SolarSkin Coating: a spray-on solar film that turns walls and windows into power-generating surfaces.”
Most homeowners can’t install traditional solar panels due to:
  • Limited roof space
  • High installation costs
  • Design restrictions in rentals or apartments
Spray-on solar coating removes these limits by allowing solar generation on almost any surface — including walls, windows, and curved exteriors — making clean energy more accessible and design-friendly.
3. How It Works
  • Core technology: Perovskite-based nanomaterial that absorbs sunlight and converts it to electricity
  • Power specs: Current prototypes reach up to 15–20% efficiency in lab conditions
  • Connectivity: Coating links to micro-inverters that integrate with existing home power systems
  • Installation workflow: Applied like spray paint on prepared surfaces → dries into a photovoltaic film → connected to the home’s energy system
4. Why It’s New or Better
  • Unlike bulky silicon panels, it’s ultra-thin, flexible, and even semi-transparent for use on glass
  • Requires no mounting hardware or roof drilling
  • Backed by recent research from MIT, with multiple early-stage patents filed globally
  • Early funding from energy startups and clean-tech accelerators in the EU and U.S.
How you can use it in real world.
Scenario: A homeowner in London wants to reduce grid reliance but can’t mount panels due to poor roof orientation.
  • Applies SolarSkin to 40 sqm of external wall and patio glass
  • Total cost: ~$3,200 (including inverter and system)
  • Expected generation: ~4kWh/day
  • ROI: 2–3 years, depending on energy rates
Plus, it doesn’t alter the home’s design or require permits.
Limitations & Open Questions
  • Durability: Needs improved weather resistance for long-term outdoor use
  • Efficiency: Slightly lower than traditional panels, especially in harsh heat
  • Certification: Still undergoing regulatory testing for residential use
  • Availability: Only offered in pilot programs — not yet commercially mass-produced
In Conclusion
Spray-on solar coating like SolarSkin is still in its early stages, but it represents a massive shift in how we think about energy in home renovations.
Instead of relying on bulky rooftop panels, homeowners could one day generate power from walls, windows, and even fences — all with a simple spray.
It’s not fully ready for mass adoption yet, but when it is, it could:
  • Lower energy bills
  • Open up solar access for renters and small homes
  • Make clean energy invisible and design-friendly
This isn’t just an upgrade — it’s a whole new category of home energy tech.
:speech_balloon: What Do You Think?
Would you spray this on your home if it meant cutting your light bill in half?
Or would you wait until it’s more tested and available?
Let’s hear your thoughts.
This is really really nice
Good job brother THANKS Buddy
