When it comes to tiling flooring, homeowners often wonder if removing the toilet is necessary. The answer is not a simple yes or no. In this article, we’ll explore the pros and cons of removing the toilet before tiling flooring, helping you make an informed decision for your next renovation project.
The Case for Removing the Toilet
Removing the toilet before tiling flooring offers several benefits:
- Easier Access: With the toilet out of the way, you’ll have unobstructed access to the entire floor area, making it easier to lay tiles and ensure a professional finish.
- Proper Floor Preparation: Removing the toilet allows you to properly prepare the floor surface, including removing old flooring, leveling the subfloor, and installing an appropriate underlayment.
- Reduced Risk of Water Damage: Tiling around the toilet can lead to unevenness and water damage. By removing the toilet, you can ensure a watertight seal and prevent costly repairs down the line.
The Case for Not Removing the Toilet
While removing the toilet offers several advantages, there are situations where it might not be necessary:
- Time and Effort: Removing and reinstalling the toilet can be a time-consuming and labor-intensive process.
- Additional Cost: If you’re not comfortable with DIY projects, hiring a professional to remove and reinstall the toilet can add to your renovation costs.
- Minimal Tile Cuts: If you’re using a tile pattern that requires minimal cuts around the toilet, you might be able to get away with tiling around it.
Tips for Tiling Around the Toilet
If you decide not to remove the toilet, here are some tips to keep in mind:
- Measure Carefully: Take precise measurements to ensure your tiles fit around the toilet base.
- Use a Laser Level: A laser level can help you achieve a straight and level tile installation.
- Seal the Gaps: Use a waterproof sealant to fill any gaps between the tiles and the toilet base.
Removing the toilet before tiling flooring is not always necessary, but it’s highly recommended for a professional and stress-free renovation experience. If you do decide to tile around the toilet, make sure to take precise measurements, use a laser level, and seal the gaps to prevent water damage. Ultimately, the decision to remove or not remove the toilet depends on your specific situation, DIY skills, and renovation goals.
