Roofing Renovation Guide: Budgeting for Your Project in Acton, Milton, Oakville, Burlington, Mississauga, Caledon, Etobicoke, Georgetown
Planning a roofing renovation project? Be it an asphalt roof replacement or a shingles roof installation, it’s essential to have a comprehensive understanding of the costs involved. Here’s a breakdown of what you can expect.
Know Your Costs: A Detailed Breakdown
The first step in any home renovation project is understanding the costs. For asphalt roof replacement, expect the average cost per square foot to range from $4 to $7. Don’t forget to account for the removal of your old roof, which will range from $1 to $3 per square foot.
If you’re considering a shingles roof installation, similar costs apply. The average cost per square foot for installation is between $4 and $7. Labour costs for a 2400 sq.ft. installation hover between $4,000 and $7,000. And again, to remove your old roof, expect to shell out between $1,000 and $2,500.
Several local factors can influence the cost of your roofing project, such as regional climate, local building codes and regulations, and the current state of the economy. Material availability can also affect costs, so bear this in mind when planning your renovation.
To ensure you’re getting the best deal, it’s advisable to obtain multiple quotes from local roofing contractors. By comparing estimates, you can make an informed decision that suits your budget and project requirements.
The Impact of Material and Labour Costs
The type of roofing material you choose significantly affects the cost. For instance, the price per square foot of any roofing shingles depends on the grade of material used. Labour costs can also vary, depending on the complexity of the roof design, the experience of the roofing contractors, and the local labour market.
The Bottom Line: The Cost to Replace a Roof in 2024
As of 2024, the estimated cost to replace the roof of a 2,000 square foot home in Oakville, Ontario, is approximately $10,000. This estimate includes materials, labour, and additional costs such as permits and disposal fees.
Final Thoughts
Ultimately, the success of your roofing renovation project lies in careful planning and budgeting. Remember to consider all factors, from material and labour costs to local regulations, and seek multiple quotes before making a decision.
Explore our web forum for more advice from experienced homeowners and industry experts. You can also check out our list of home service pros for a professional opinion on the benefits of metal and asphalt roofs.
Whether you’re replacing a deteriorating roof or simply seeking a change, a well-executed roofing renovation can significantly enhance the value and aesthetic appeal of your home. Good luck with your renovation journey! ![]()
