Renovating a home is akin to a journey - exciting, rewarding, but also filled with challenges. One of the major hurdles homeowners across Ontario face is the cost of foundation repairs, particularly parging foundation, and the various factors that affect it. Parging is the application of a protective and decorative layer of mortar to the exposed surface of a building’s foundation. Over time, weather conditions, moisture, and natural wear and tear can cause this parging layer to crack or deteriorate. So, let’s delve into the elements that influence the cost of these repairs and provide a detailed breakdown.
Firstly, one of the primary factors that affect foundation repair costs in Ontario is the soil condition, particularly in the basement. The local climate in Ontario can also influence foundation repair costs. The location and extent of foundation damage can also impact the choice of repair method and in turn, the expense.
The average cost range for crack repairs can vary depending on several factors, including the severity of the damage and the materials used. Prompt repairs prevent further damage and help maintain the protective and aesthetic qualities of your foundation. For instance, a bowing brick wall, a common masonry problem, can cost around $55 to $65 per square foot to repair. Brick repointing, which is required when bricks degrade and the joints start to crumble, also adds to the overall cost.
When it comes to masonry facade repair, it’s one of the most expensive in the industry. Using ballpark estimates, strip and reshingle with premium quality asphalt shingles might cost you $5.00 – $10.00 per sq.ft. Installing galvanized or aluminum gutters and downspouts could range from $5.00 – $10.00 per lin.ft. Repointing an exterior wall with hard mortar can cost similarly.
One factor that homeowners often overlook when budgeting for foundation repairs is the cost of building permits. Completing an Application for a Permit to Construct or Demolish and submitting it to the Town Office for review is part of the process. This may result in additional costs that should be factored into the overall budget.
After understanding the cost breakdown, it’s crucial to take into account the local factors that might affect these costs. For instance, Ontario’s climate might require specific materials or techniques to ensure the longevity of the repairs.
Choosing to repair damaged foundation parging promptly is essential. Not only does it prevent further damage, but it also helps maintain the foundation’s protective qualities, which, in the long run, might save you significant repair costs.
Our discussion doesn’t end here. Join our web forum to discuss this topic further, share your experiences, and learn from others. Remember, knowledge is power when it comes to home renovation. So arm yourself with the right information before embarking on your renovation journey.
