Using a large scale tiles in your bathroom
The use of large-format tiles within bathroom design has vastly increased in popularity. Previously, it tended to be the tile size of choice for wet rooms, but the high-end appeal of a sleek, seamless surface area with minimal grout lines is now often preferred over the busy look attained by groupings of smaller tiles.
With a vast surface, large-scale tiles can elongate a room, providing an unbroken, sweeping view of visual continuity that makes smaller spaces feel bigger. They are also easier to clean and maintain, making them the perfect choice for those with a busy or hectic lifestyle.
beige large tiles bathroom
Terrae Bianco is used here on the floor and on the adjacent side to a busier feature wall for visual balance.
Luxury Italian tile manufacturers Casalgrande Padana offer a wide range of available in multiple finishes, textures and colours. Size options include 20x120 cm, up to 160x320 cm, with a thickness of 6 mm or 12 mm (the 12mm thickness was designed to create bathroom tops).
Why not use the same large-scale tiles on the wall and floor such as Lithos Beigie for a soft and muted backdrop for vibrant fixtures, bathroom accessories, or to not distract from a window view. You could also combine lighter, earthy-toned large-scale tiles such as Bianco with a busier pattern for visual balance.
modern bathroom design idea
Lithos Beige on the floor and most of the wall surface is the perfect muted backdrop for a striking piece of bathroom furniture that doesn’t distract from the window view.
Choosing the right tiles will bring out the beauty
This is really informative mate
Keep on doing the good work
The right tiles really make a huge difference
Such a satisfying before-and-after.
You are making sense friend
These could be huge game changers
Great article brother
Truly motivating, your message strengthens the spirit.
