The Cutting Companion
A utility knife is a versatile tool used in almost every home renovation project. It has a sharp, replaceable blade and a handle designed for a comfortable grip. This knife can cut through materials like cardboard, drywall, carpet, vinyl, or even thin wood, making it indispensable for precise work.
To use a utility knife safely, hold it firmly and apply steady pressure while cutting along a straight edge or guide.
Always cut away from your body to prevent accidents, and retract the blade when not in use.
Changing the blade regularly ensures clean cuts and reduces the effort needed. A utility knife may seem simple, but it saves time and improves accuracy, making tasks like trimming, scoring, or shaping materials much easier in any renovation project.
