In renovation projects, contractors are often asked to compare vinyl plank and laminate flooring. Both are designed to replicate the look of natural materials while remaining budget-friendly, yet their performance differs significantly. Vinyl plank flooring is built from PVC, making it completely waterproof. This makes it a strong candidate for bathrooms, basements, and kitchens where spills or moisture are frequent. Laminate, on the other hand, is made from a fiberboard core topped with a photographic layer. While durable against scratches, it is more vulnerable to water damage.
Installation methods for both are similar, usually involving click-lock systems that make floating floors quick to install. Vinyl is more forgiving over uneven subfloors, while laminate often requires a more carefully prepared base. In terms of comfort, laminate can feel harder underfoot, whereas vinyl offers more flexibility and warmth. Appearance is another consideration. Laminate often provides a more realistic wood texture, while vinyl wins in performance.
For contractors, the decision often comes down to lifestyle and room use. Busy households with kids and pets may benefit more from vinyl, while bedrooms or living areas may suit laminate just fine.
Conclusion: Knowing the strengths and weaknesses of vinyl plank and laminate helps renovation professionals guide homeowners toward the right solution. Both have their place in modern projects, but the key is matching the material to the demands of the space.
