Featured DIY Projects
- Install a DIY Stair Runner
Overview: A weekend-friendly project that instantly adds texture and warmth to your staircase.
Steps:
Remove existing carpet/runner and sand edges.
Fill imperfections with wood filler and paint wood areas.
Use double-sided carpet tape for positioning, then secure runner with carpet tacks or staples.
Cost: Materials like tape, filler, and runner are affordable—project stays under $200.
Timeframe: One day for prep and one day for installation.
- Replace Door Handles and Hinges
Overview: Swapping out old handles and hinges refreshes your space with minimal effort.
Steps:
Remove existing hardware using a screwdriver.
Match hinge types and purchase replacements.
Install new handles—and hinges, if needed.
Cost: Many affordable options available (e.g., packs of knobs around $20).
Impact: High visual impact for minimal spend.
- Paint Your Fireplace
Overview: A dramatic makeover using heat-resistant paint.
Steps:
Clean the surface to remove soot.
Apply a high-temperature primer.
Add two coats of black stove paint.
Cost: Often around $50 for proper materials.
Timeframe: 6–8 hours total—feasible in one weekend.
- Install a Tiling Backsplash
Overview: Elevates kitchen or bathroom walls with peel-and-stick or sheet tiles.
Steps:
Prep and smooth wall surface.
Apply peel-and-stick or mesh-backed sheet tiles.
Grout as needed.
Cost: Budget-friendly, often under $200 depending on size.
Timeframe: 4–6 hours—perfect for a single weekend.
- Redecorate Your Front Door
Overview: A quick visual update that greets guests with style.
Steps:
Clean door surface thoroughly.
Paint using high-performance enamel spray paint.
Optional: Add a stylish door knocker.
Cost: Enamel spray paint (~$30–$50), door knockers still affordable (e.g., around $45).
Timeframe: 3–4 hours—fast and effective.
Project Comparison Table
Project Estimated Cost Time Required Key Benefits
DIY Stair Runner Under $200 2 days Enhances comfort and design of staircase
Door Handles & Hinges Under $200 <1 day Easy update to refresh interior hardware
Paint Fireplace ~$50 ~6–8 hours Bold visual transformation with minimal spend
Tiling Backsplash Under $200 4–6 hours Stylish and protective wall treatment
Front Door Redecoration Under $200 3–4 hours Instant curb appeal upgrade
Why These Projects Work for a Weekend
Budget-conscious: All fit comfortably within a $200 limit.
Weekend-sized: Clear timeframes; many can be completed in less than a day.
High-impact: Low-cost tweaks yield noticeable upgrades—ideal for making spaces feel fresh without full renovations.
