What Building Code Changes in 2025 Mean for Your Remodel
Thinking about renovating? It’s wise to stay on top of the coming code changes. These updates touch on everything from materials and safety to energy use, and they could shift your budget and schedule.
  1. Fire Safe Vents in High Risk Fire Zones
If you’re in an area prone to wildfires, new codes call for special vents that can resist flames for attics and crawl spaces.
These vents help keep embers and flames out, making your home safer.
  1. Stricter Rules for Energy Savers
Starting in 2026, be ready for tougher rules about insulation, windows, and air systems.
Heat pumps might become the go-to for heating and cooling.
For both new builds and remodels, you might need to prep for solar panels with wiring and roof supports.
  1. Better Earthquake Resistance
If you’re in an earthquake zone, expect stronger rules for how buildings stand up.
Homes that aren’t braced well or have weak lower floors might need extra support.
  1. Easier Access for Everyone
Remodels should include features that make things easier for people with disabilities, mainly in multi-family houses.
Think wider doors, no-step entries, and bathrooms and kitchens that are easy to use.
  1. Materials That Resist Fire
Many states now want fire-resistant siding, roofing, and trim on new buildings or big remodels.
  1. Eco-Friendly Building & Tech
Builders are being pushed to use materials that are easy on the environment, like low-carbon concrete and recycled insulation.
Some codes also want smart home features that save energy and boost safety.
When Do These Rules Start?
In California, the updates, including the energy code, kick in on January 1, 2026.
Other states might roll out their own changes in 2025 or soon after.
Wrapping Up
These code updates might add a few steps to your remodel, but they’ll make your home safer, greener, and set for the future. Planning ahead and using contractors who know the latest codes will help you dodge delays, pass inspections, and get the most value from your remodel.
I’ll have to take note of this
I’ll remember to take notes
Will definitely take note of this
Take note of it cause it will help you
Good , And make use of it though
Good , Try it also
Thank you
