What do gutter guards do?
Gutter guards are designed to keep debris like leaves and twigs out of your gutters while allowing water to flow through. They help to minimize the need for frequent gutter cleaning and can protect your home from water damage.
Gutter guards function by creating a barrier that prevents larger debris from entering the gutter system. This helps maintain proper water flow and reduces the risk of clogs. However, it’s important to note that while they significantly decrease maintenance, they are not completely maintenance-free. Some debris can still accumulate on top of the guards, so occasional cleaning is necessary.
Key Benefits of Gutter Guards:
  • Reduced Maintenance: Gutter guards can cut down the frequency of gutter cleanings, which is especially beneficial for homes surrounded by trees.
  • Prevention of Water Damage: By keeping gutters clear, they help prevent water from overflowing, which can lead to foundation issues and damage to your home’s exterior.
  • Ice Dam Prevention: While they don’t eliminate the risk, gutter guards can help reduce the likelihood of ice dams forming by keeping gutters free of debris.
Considerations Before Installation:
  • Types of Gutter Guards: There are various types, including mesh screens and solid covers, each with different levels of effectiveness and installation costs.
  • Cost: The average installation cost for gutter guards can range from $650 to $2,000, depending on the type and size of your home.
  • Weight and Structural Integrity: Some gutter systems, especially older ones, may not be designed to handle the additional weight of gutter guards, which can lead to sagging or damage.
Maintenance Tips:
  • Regular Inspections: Even with guards, inspect them periodically to ensure they are functioning properly and clear of debris.
  • Professional Help: If you’re unsure about installation or maintenance, consider consulting with a professional to assess your specific needs.
In summary, gutter guards can be a valuable addition to your home renovation strategy, especially if you are looking to minimize maintenance while protecting your property from water damage. Just remember to choose the right type for your needs and keep up with regular inspections.
