The best way to construct a retaining wall depends on the size of your project, soil type, and purpose of the wall. For most residential projects, here are some general steps that work well:
Plan and Design: Decide on the type of wall (timber, concrete sleepers, or stone) and measure the area carefully.
Excavate and Level: Dig a trench where the wall will sit and make sure it’s level and compact.
Lay a Solid Base: Use crushed rock or gravel as the foundation. This helps with drainage and prevents the wall from shifting.
Build in Layers: Place your blocks, sleepers, or timber row by row, checking that each layer is level.
Add Drainage: Always install drainage behind the wall (like gravel and a drainage pipe) to prevent water pressure from damaging it.
Backfill and Finish: Fill behind the wall with gravel or soil and compact it properly.
If it’s a small DIY wall, timber or interlocking blocks are usually easiest. But for taller or load-bearing walls, it’s best to hire a professional, because engineering and proper permits may be required.
