What’s the best way to soundproof a room on a budget?
To soundproof a room on a budget, you can try several cost-effective methods. First, consider using thick curtains or blankets over windows and doors to help block sound. Adding rugs or carpets can also absorb noise, especially if you have hard floors. You might also rearrange furniture, like bookshelves, against walls to act as sound barriers. Weatherstripping doors and windows can reduce noise leakage. Lastly, using foam panels or egg cartons on walls can help dampen sound. These methods are affordable and can significantly reduce noise without requiring major renovations.
Alright Bobby
Thank you
To soundproof a room on a budget, prioritize sealing air gaps around doors and windows with caulk, weather-stripping, or foam gaskets, and use soft, dense materials like heavy curtains, rugs, furniture, and blankets to absorb and block sound
Alright noted brother
Thanks
