What’s the easiest way to upgrade old windows?
What’s the easiest way to upgrade old windows?tr
Weatherstripping & Caulking
Seal gaps and cracks to stop drafts.
Inexpensive, quick, and instantly improves
Thanks for sharing your idea
You are welcome thank you
This could refer to either physical windows in a building or possibly an older version of the Windows operating system on a computer. If it’s about physical windows, upgrading might involve adding insulation, replacing glass panes, or installing new window frames to improve energy efficiency and appearance. If it’s about the Windows operating system, upgrading could mean installing a newer version of the software to access updated features and security improvements.
Thank you for your contribution sir
Add caulk and weather-stripping to seal air leaks, install window inserts or storm windows for better insulation, or apply energy-saving window film
Thank you for this tip
Alright noted Boss thanks boss
You are welcome brother :ok_hand:
