Which deck ledger flashing details actually survive two decades—membranes, metals, and shingle integration?
Good copper or quality aluminum flashings put under shingles or siding with a good slope can last for years. Peel-and-stick stuff works well if it’s out of the sun. Keep things clean and check the sealant to make them last even longer.
Metal flashing with proper shingle overlap lasts longest; membranes fail faster unless fully protected and well-integrated.
For 20+ year ledger life: metal flashing and self-adhered membrane and proper shingle/siding overlap, with slope and sealed fasteners.
The longest lasting ledger flashing setups pair a corrosion resistant metal like stainless steel or heavy gauge aluminum with proper shingle style integration behind the siding and over the ledger plus a self sealing membrane over framing before metal install. Key to two decade survival is leaving a drainage gap between ledger and house wall, using kickout ends to shed water, and avoiding direct contact between treated lumber and metal without a barrier
For longer survival:
Best: Self-adhered membranes (like Trex Seal), copper, stainless steel.
Shingle integration: Use drip cap/Z-flashing above ledger; seal fasteners behind.
Avoid: Aluminum or galvanized on pressure-treated wood.
For 20-year performance, use corrosion-resistant metal (stainless or coated aluminum/zinc) over a self-adhered membrane, integrated under shingles and siding with end dams. Metal shields the membrane from UV, and proper layering, slope, and drainage ensure long-term protection.
