Why Aluminum Roofing Sheets Are No Longer “It”
Aluminum roofing, once a popular choice for homeowners, is slowly losing its shine due to several drawbacks.
Reasons for Declining Popularity
  • Aesthetic Concerns: Aluminum roofing tends to lose its original color and becomes washed out and spotty over time due to weathering and oxidation. This can be mitigated by using painted roofing coils or panels.
  • Denting and Damage: Aluminum is more prone to denting from impacts, such as hail or falling branches, compared to other metals like steel. This can compromise the roof’s appearance and potentially lead to maintenance issues.
  • Thermal Expansion and Contraction: Aluminum expands and contracts roughly twice as much as steel, which can cause issues like “oil canning” (a wavy appearance), heightened noise levels, and greater maintenance requirements for exposed fasteners.
  • Higher Maintenance: While aluminum roofing is generally durable, it requires more maintenance than other materials due to its susceptibility to denting and potential for leaks if not installed correctly.
  • Cost: Although aluminum roofing is recyclable and durable, its initial cost can be higher than other materials, including the cost of specialized labor for installation…
Comparison to Other Materials
  • Steel Roofing: Steel roofing offers greater strength and durability compared to aluminum, with less susceptibility to denting. However, it’s heavier and may require additional structural support.
  • Copper Roofing: Copper roofing is highly durable and resistant to corrosion, with a unique aesthetic appeal that develops over time. However, it’s more expensive than aluminum and may not be suitable for all budgets.
  • Galvalume Roofing: Galvalume roofing is a popular alternative to aluminum, offering excellent durability and corrosion resistance. It’s often preferred for its ability to withstand harsh weather conditions
While aluminum roofing has its benefits, including energy efficiency and recyclability, its drawbacks are driving homeowners to consider alternative materials.
Thank you for sharing this
Continue doing the good work bloke…
I also do believe that they are old trend
You are making sense here
The image says it all
This great and well detailed
