Tr
Basements can be tricky spaces to renovate, and that goes especially for flooring. Many homeowners love the natural look of wood, but the use of solid hardwood below ground is often an expensive mistake. Moisture, even in small amounts, can cause warping, buckling and permanent damage to solid planks.
This is where engineered wood comes in to be the smarter choice. Unlike solid wood, engineered wood is composed of several layers of wood which are joined together. The outer top layer is real hardwood for beauty and the inner layers are made for stability. This layered structure helps it to resist the natural expansion and contraction which occurs in damp or humid basements.
Engineered wood also works well with modern installation systems including floating floors. Paired with moisture barriers or underlayment it is a solid barrier against basement conditions. Homeowners get the warm and ageless look of wood without the stress of constant repairs and replacements.
The other benefit is cost efficiency. Engineered wood is usually available at a lower cost than solid hardwood, and is practical as well as stylish.
Solid hardwood looks elegant, but has problems in basement environments. Engineered wood has all the charm but with much greater resilience to moisture and changes in temperature. Selecting it makes sure that your basement renovation will be beautiful, durable and stress-free for years to come.
