Ceramic tiles have been the default flooring choice in Ontario for years.
But lately, many contractors are no longer recommending them, and most homeowners are not being told why.
This shift is not about style alone. It is about cost, labour, and risk.
Labour costs are changing the equation
In Ontario, skilled tile installers are charging more due to labour shortages and higher operating costs. Tile installation also takes longer compared to newer flooring options. For contractors working on tight schedules, ceramic tiles now slow projects down.
Cracked tiles and grout issues are also leading to more callbacks, especially in older homes with uneven subfloors, which are common across Ontario.
What contractors are recommending instead
More builders are pushing clients toward alternatives that reduce installation time and long-term issues.
SPC flooring is one of the biggest replacements. It installs faster, handles moisture better, and avoids grout problems. Many contractors now suggest it for kitchens, basements, and living areas.
Large-format porcelain slabs are also gaining popularity in higher-end renovations. They offer fewer grout lines and a cleaner finish, which appeals to modern Ontario homes.
In condos and urban renovations, polished concrete and microcement are becoming more common due to faster turnaround and a minimalist look.
The real issue is total project cost
While ceramic tiles still look affordable on paper, the full cost tells a different story. Adhesives, skilled labour, and potential repairs often push tile projects higher than expected.
That is why some Ontario contractors now increase quotes when clients insist on ceramic tiles.
Why this matters if you are renovating in Ontario
If you are planning a renovation in 2026 and assuming ceramic tiles are the safest option, you might be paying more and increasing the risk of delays.
The market is shifting, even if it is not being openly discussed.
Open question
If you have renovated recently in Ontario, were you advised to avoid ceramic tiles?
Do you think tiles still make sense, or are they slowly being phased out?
