In Pittsburgh, Pennsylvania, two houses on the same street went through renovations at the same time. One project moved smoothly. The other ran into constant problems.
The difference was not budget or contractors. It was the property itself. Older homes with solid framing and clear layouts often renovate better than newer builds with tight mechanical spaces and rushed construction.
Understanding a property’s bones before renovating saves time and money. Things like ceiling height, joist spacing, and access to plumbing matter more than finishes.
The smartest renovations start by respecting the property you are working with
