With FEMA Risk Rating 2.0 fully implemented, which retrofits most reduce premiums in practice?
Okay, so with FEMA’s Risk Rating 2.0, if you want to cut down on flood insurance costs, focus on upgrades that really stop flood damage. Usually, that means:
- Raising the lowest floor higher than expected flood levels.
- Putting in good flood vents in any enclosed spaces under the raised floor.
- Moving or lifting up mechanical stuff such as electrical panels, and HVAC systems so they are above flood level.
- Using materials that can handle flood damage on lower floors.
Other things, such as better drainage or backflow valves, can help with damage, but they might not affect your premiums as much unless they change how FEMA rates your building. You’ll need pictures, elevation certificates, and records of the work to get credit for the fixes.
