With limited front-yard depth and 2–3 entry steps, which ramp geometries (switchback, L-shaped) or compact lifts meet s…
With limited front-yard depth and 2–3 entry steps, which ramp geometries (switchback, L-shaped) or compact lifts meet slope/landing code while preserving curb appeal?
Don’t have room for a straight ramp? Try a switchback or L-shape. If you’re really tight on space, a vertical lift could be the answer. Just double-check everything meets local safety rules for ramps, like the slope and landings. Plus, you can still make it look awesome with a bit of planning!
To meet slope and landing code requirements while preserving curb appeal, consider the following options for your limited front-yard depth with 2-3 entry steps:
Ramp Geometries
-Switchback Ramp: This design allows for a more compact footprint while meeting slope requirements. A switchback ramp has two parallel runs connected by a landing, enabling a 180-degree turn. This design requires a minimum landing size of 60" x 60" to facilitate wheelchair turns.
-L-Shaped Ramp: This design features a single run with a 90-degree turn, which can be more space-efficient than a straight ramp. Ensure the landing area is at least 60" x 60" to allow for safe turns.
Compact Lifts
  • Vertical Platform Lifts: These lifts are ideal for limited spaces and can be installed with minimal excavation. They provide a compact solution for accessibility, often with a smaller footprint than ramps.
  • Portable Ramps: These ramps are versatile and can be used temporarily or permanently. They’re available in various lengths and can be customized to fit specific needs.
If you’ve got a shallow front yard and just 2–3 steps at the entry, you’ve got a few solid options that meet code without killing your curb appeal:
Ramp Options
  1. L-shaped ramp
Turns 90° at a landing, so it fits better in tight spaces.
Works well when one side of the yard has more room.
You’ll need around 14–16 feet of total run for 2–3 steps.
  1. Switchback ramp
Makes a U-turn at a landing, stacking the run back on itself.
Takes up more depth, but can work if you don’t have the width.
Can be tucked into landscaping to make it less obvious.
  1. Parallel-to-house ramp
Runs alongside the house, then turns into the entry.
Keeps the ramp low-profile and easy to hide with shrubs or fencing.
Lift Options
  1. Vertical platform lift
Great if you’re short on space and don’t want a long ramp.
Needs about a 5’x5’ pad and clear access.
Looks clean and modern, especially if you box it in or match it to your exterior
